Havenwood | Дата: Четверг, 08.11.2012, 15:09 | Сообщение # 1 |
| Здравствуйте, я пытаюсь восстановить Ка-25 Вертолет Fly Model (количество 065). Это оригинальный файл.
А это, как я была восстановлении немного серого.
Я хочу сделать что-то в этом стиле, с четко определенной линии фюзеляжа и черный и носить иметь такую силу, как я могу сделать с Photoshop?
Привет!
PS: я не говорю на русском, поэтому, пожалуйста, простите любой сбой в письменной форме.
Gunns | Дата: Четверг, 08.11.2012, 17:51 | Сообщение # 2 |
| Havenwood, Hi ! Probably you're using a translator. So you want to re-paint the old model.. I'm not a guru in Photoshop, but can help you a little...
First, you need to create layers in PS. Each layer is for definite purpose: for contour, for rivets, for insignia, for some stencil data, effects (such as weathering, scratching, oil licking etc...) After you made those layers (some new you can make during the repainting if necessary), in layer "Contour" with brush (1, 2 or 3 pixels - depends on case) start to draw the details. Straight line you can draw with holding the "Shift" button. Ovals you can draw with instrument "Elliptical Marquee Tool", circles - with the same tool, but holding the "Shift" button. To set a thickness of it, when drawn, click of RMB on it and select "Stroke", you can see the field to set pixels and type of stroking - "Inside", "Center" and "Outside". If you want to fill it with some color - just choose "Fill". For riveting - in layer "Rivets" set the necessary spacing for brush tool, point the start of rivet line, the other is easy - just like with common line. For weathering - in it's layer play with brush tip shape, it's size, and the color. Just see the scans above to get the same effect. You can also use some effects on layer (double click on the layer).
You can read the translated page of your member slider2000: http://translate.google.com/transla....act=url
Also I recommend to read this forum: http://www.simmerspaintshop.com/forums/forum37-photoshop/
Not much, but I hope this will help.
Cheers, Sergey
Сообщение отредактировал Gunns - Четверг, 08.11.2012, 17:52 |
Havenwood | Дата: Пятница, 09.11.2012, 13:26 | Сообщение # 3 |
| Очень полезная информация.
Спасибо вам большое!
PS: Так Gunns, я помогаю с переводчиком Google
fasa46 | Дата: Воскресенье, 11.11.2012, 19:09 | Сообщение # 4 |
| Havenwood this link will help you
http://www.simmerspaintshop.com/forums....ing-461
Havenwood | Дата: Вторник, 13.11.2012, 00:10 | Сообщение # 5 |
| Здравствуйте, fasa46, большое спасибо за информацию.
Я начал использовать Corel Draw, чтобы нарисовать контур вертолета, а затем передать его в Photoshop и начинаем рисовать испытаний. Это картина того, как вы находитесь.
Если кому-то интересно, могу поделиться файлами, если они порождаются некоторым Forumer хочет присоединиться к проекту.
С уважением -------------------------------------------- Hello, fasa46, thank you very much for the information.
I started using Corel Draw to draw the outline of the helicopter, and then pass it to Photoshop and start painting tests. This is a picture of how you are staying.
If anyone is interested, I can share the files if they are generated by some forumer wants to join the project.
regards
