Четверг, 19.11.2026, 04:54
  • Страница 4 из 4
Ил-10 моей мечты
LukasДата: Понедельник, 21.04.2025, 05:25 | Сообщение # 46
Kirill102 , It's not problem with shape, it's problem with proportions.. The nose is simple too long, goes to far down. You need to measure the whole model and its proportions.
ModellerДата: Понедельник, 21.04.2025, 05:53 | Сообщение # 47
Lukas, U should consider the perspective impact with such approach with just one side view. Otherwise take bunch of photos the way it can be neglected more or less. Each photo will be responsible for a small angle to work with. U can't just use the straight side view of the whole thing and say that's no problem, the blueprint is ready. It has tremendous impact on it, and this should be considered. There is a solution that already discussed in my profile signature, how to do it.
3DMax
3D фотограмметрия
Формовка листового металла
Kirill102Дата: Среда, 13.08.2025, 00:21 | Сообщение # 48
Игроделы задают стандарты: https://il2-korea.ru/news/dd_24
LukasДата: Четверг, 19.03.2026, 04:20 | Сообщение # 49
Never finished project angry wink
Advokats666Дата: Суббота, 21.03.2026, 03:49 | Сообщение # 50
Lukas,
This is not a new project... only correction of nose part IL-10 from old project of Alexandr Fabrichniy
LukasДата: Суббота, 21.03.2026, 19:03 | Сообщение # 51
Yes, Im writing about nose of the model. I don't understand why to even start a project and never finish. Project is now abandoned.
Advokats666Дата: Воскресенье, 22.03.2026, 01:07 | Сообщение # 52
Lukas, write please to the theme author
LukasДата: Понедельник, 23.03.2026, 00:46 | Сообщение # 53
I did, but He did not answer.
  • Страница 4 из 4
